Napisał
danus77
Jeśli sam wyciągałeś schemat z Elearn'a to miałeś tam opis:
K79 -Air temperature sensor (additional heater) / Interior temperaature. sensor for additional heater
oraz:
Pin 3 of connector A of M75 receives a signal from the appropriate temperature sensor K79 , which measures air temperature within the engine bay.
The sensor only works with the engine running; it receives a reference signal from alternator (D+); this signal is low (earth) when the alternator is not turning. The signal becomes high (12 V) and supplies the sensor when the engine is running.
Jest to czujnik temperatury schowany przy lewym błotniku, na podstawie którego sterownik Webasta decyduje o jego uruchomieniu.
Natomiast odgałęzienie do E5010, to po prostu połączenie altka z rozrusznikiem.
