Show results from 21 to 30 with 40
27-10-2014, 16:43 #21The user The alpha and the Omega
- He joined the
- 05 2011
- Lives in
- Oswiecim
- Auto
- Renault Scenic 1ph2
- Posts
- 434
no i dzis plus 8, aku ladowany, dwa krecenia i chyba znowu padl, jutro sproboje odpalic na kable i jesli pomoze to jade po aku, jesli nie to plak w dolot i warsztat.
› Więcej...: 2.4 jtd does not smoke as it is cold, smokeIt was:
Daewoo Tico 0.8
Opel Vectra B 1.8
Alfa Romeo 166 2.4 jtd
Alfa Romeo 156 2.5 v6
Alfa Romeo 156 sw 2.4 jtd
Is:
Renault Scenic 1.4 1ph2
28-10-2014, 17:28 #22The user The alpha and the Omega
- He joined the
- 05 2011
- Lives in
- Oswiecim
- Auto
- Posts
- 434
kupilem nowy aku, plus 6 temp, odpalila "od strzala" praktycznie, light is swiec mruga.
It was:
Daewoo Tico 0.8
Opel Vectra B 1.8
Is:
30-10-2014, 03:17 #23
If light is mruga to coś albo z połączeniem fajek od świec bądź którąś może być spalona
30-10-2014, 06:39 #24
fajki od świec w JTD?
Sent from S3
30-10-2014, 08:44 #25The user The alpha and the Omega
- He joined the
- 05 2011
- Lives in
- Oswiecim
- Auto
- Posts
- 434
It was:
Daewoo Tico 0.8
Opel Vectra B 1.8
Is:
30-10-2014, 13:31 #26
30-10-2014, 19:58 #27
02-11-2014, 13:19 #28
02-11-2014, 14:16 #29
Prawdopodobnie jest ok. U mnie jest 270bar, ale może zależy to od sterownika, ktory w 166 pewnie jest inny. Niemniej chyba powinieneś sprawdzić pompę w pełnym zakresie obrotów, nie tylko na wolnych.
03-11-2014, 20:07 #30
Similar threads
His eyes are black, he's stronger and more smokes
Created by arekbz in the section of the GTResponse: 6Last post/author: 20-08-2014, 10:57 -
156 smoke a HUGE amount of oil smoke
Created by mechanik in section 156Response: 16Last post/author: 10-01-2014, 16:29 -
CODE does not go off when it's cold
Created by 16v in section 156Response: 6Last post/author: 01-02-2013, 20:32 -
Firing when it is cold ???
Created by sylwek9161 in section 156Response: 3Last post/author: 13-01-2012, 12:28 -
A lot of smoke, a little smoke, momentary power-PRZEPLYWKA PROBABLY NOT
Created by jacek51415 in section 147Response: 3Last post/author: 05-11-2009, 16:03
