FES pokazał mi taki oto komunikat, gdzie szukać dokładnie tego problemu, dodam, że wtyczki pod fotelem pasażera oraz w bagażniku polutowane.
The ECU detected a short to Ground or Battery + in the Seat Belt Pre-Tensioner Squib circuit(s) as indicated by the code.
ATTENTION! TURN THE KEY OFF FOR AT LEAST 10 MINUTES, THEN DISCONNECT THE BATTERY AND WAIT FOR 15 MINUTES, THEN DISCONNECT THE AIRBAGS.
After disconnecting the Airbags, inspect the wiring for the short, and replace the harness if faulty.
NOTE: In some cases the code may refer to both driver and passenger Belt Squib circuits, or to a defect in the ECU itself.
After completing the test and replacing the faulty parts, assemble the system and reconnect the battery as the last step. After that, read the codes and data again to ensure the system to be OK
Odpowiedz z cytatem
