Show results from 31 to 40 with 134
Subject: Crashing high voltage V6 coil
12-11-2013, 10:02 #31The user Maniac resoraków
- He joined the
- 10 2011
- Lives in
- Kalisz
- Auto
- Alpha romeo 166 2.5 v6 2004. 159 2.4 jtd in 2006
- Posts
- 572
Your method is not that strange - mechanics use stethoscopes and "stick" will work like a stethoscope
› Więcej...: Cykająca coil high voltage V6
12-11-2013, 21:13 #32The user Alfista
- He joined the
- 05 2008
- Lives in
- Poznan
- Auto
- 166 3.0V6 Sportronic | szybkie daily
- Posts
- 4,460
166 2.5 V6 CF2 Sportronic was the | 166 3.0V6 CF3 Sportronic @ 241KM / 291Nm is
My 166 Grigio Chiaro: http://www.forum.alfaholicy.org/nasz...ml#post1222435
More Alpha: https://www.youtube.com/channel/UCA7...kh5YZ4Hy4vTsew
Ekonomiczne daily: https://www.forum.alfaholicy.org/prz...volvo_v70.html
16-11-2013, 19:30 #33The user Romeo
- He joined the
- 07 2009
- Lives in
- KUTNO / Łódź
- Auto
- 166 2.5v6 2002r.
- Posts
- 599
My colleagues are starting to have more and more doubts whether this coil shoots. He has not shot for a few days mechanic As he listened he said that in his opinion it was not a coil, but a relay in the gas system from time to time. AND engine Works as a model. It has a slight wave of rotation, but it has always been I have not found a cause. I'm getting stupid. Today I took off the front cover over the coils and in the dark it can be seen that they flashed between the metal casing and the black plastic on the coil such horizontal elongated flashes on the first coil on the top and bottom of the casing and on 2 and 3 only at the bottom flashes. This is like a stroboscope. Should such flashes be? 2. Question is what is the tube connecting the intake manifold with the head on the right such a short elbow because he sees that on the top of the collector someone is wrapped insulation is some kind of odma? Does it have to be airtight? He goes in the air next to the throttle.
16-11-2013, 19:55 #34Super Moderator Quadrifoglio Verde
- He joined the
- 05 2009
- Lives in
- Strzelin
- Auto
- 166 3.0V6, gtv 2,0TS, brera V6
- Posts
- 12,644
16-11-2013, 20:24 #35The user Romeo
- He joined the
- 07 2009
- Lives in
- KUTNO / Łódź
- Auto
- 166 2.5v6 2002r.
- Posts
- 599
16-11-2013, 20:43 #36Super Moderator Quadrifoglio Verde
- He joined the
- 05 2009
- Lives in
- Strzelin
- Auto
- Posts
- 12,644
I do not know how anyone can imagine that coils with puncture on the mass are good ..... When it shines it is punctured. It's not a Christmas light that shines. The coil has no right to flash, spark or shine. The tension is supposed to go to the candle rather than the block or the head.
And the fact that someone flashes and nothing happens does not prove anything. I myself have been with the Christmas tree in other cars for some time and it was good. But you are not. If you think that's not the case, do not exchange just search further. But until one thing is wrong you can not be sure what to look for.
16-11-2013, 22:13 #37The user Romeo
- He joined the
- 07 2009
- Lives in
- KUTNO / Łódź
- Auto
- 166 2.5v6 2002r.
- Posts
- 599
17-11-2013, 10:14 #38Super Moderator Quadrifoglio Verde
- He joined the
- 05 2009
- Lives in
- Strzelin
- Auto
- Posts
- 12,644
24-11-2013, 23:02 #39The user Cyclist
- He joined the
- 03 2013
- Lives in
- Hajnowka
- Auto
- Was: 166 2.5 V6 CF3 manual/ Sportronic 166 2.4 20v 2004
- Posts
- 61
Nonsense you write that you can not see. Sam changed the coil because it fell right after the foundation LPG. It was a coil under the collector, at night as I watched it flashing like on sunrise .. Change the candles first
24-11-2013, 23:16 #40Super Moderator Quadrifoglio Verde
- He joined the
- 05 2009
- Lives in
- Strzelin
- Auto
- Posts
- 12,644
I do not write nonsense. Just look at the construction of the coil ...... It had to break the corpse and it was pierced on top. And this is a rarity. Najpart of theIt breaks the cover under the coil (this tube) because it is most heated and is most susceptible to damage. Therefore, there is nothing to look under the cover because in most cases you probably will not see anything. What's different are the WN cables. Then everything can be seen in the palm of your hand.
Similar threads
Or TS 16V possible high voltage cables?
Created by Jerry1 in section 156Response: 22Last post/author: 20-06-2014, 10:28 -
[164] High tension leads.
Created by tytus_w in the section 33/164Response: 22Last post/author: 23-01-2014, 22:19 -
[164] the high-tension cables
Created by Miłosz in the section 33/164Response: 1Last post/author: 05-10-2008, 07:49 -
[164] 2.0 TS - how to check coil of high voltage?
Created by fr33 in the section 33/164Response: 6Last post/author: 25-02-2008, 00:29
