Page 5 with 14 The firstThe first 1234567891011121314 LastLast
Show results from 41 to 50 with 134
  1. #41
    The user Romeo
    He joined the
    01 2011
    Lives in
    Gdynia
    156 2.5 V6 190HP 1999, 159 1.9JtdM 150KM 2006
    Posts
    1,317
    Do not deliberate, just exchange. Ideally for Marei 2.0 coils, they come in angled and two screws, though the cost of theThey eat pennies and give you a better spark. Checked.
    › Więcej...: Cykająca coil high voltage V6
  2. #42
    banned Romeo
    He joined the
    02 2011
    Lives in
    Bydgoszcz
    166 2.5V6 CF2 4HP20
    Posts
    655
    How did you find that the coil from Marei 2.0 gives you a stronger spark? Are you long on them?
  3. #43
    The user Cyclist
    He joined the
    03 2013
    Lives in
    Hajnowka
    Was: 166 2.5 V6 CF3 manual/ Sportronic 166 2.4 20v 2004
    Posts
    61
    Quotation Wrote marek230482 Zobacz post
    It had to break the corpse and have a piercing on the top. And this is a rarity.
    I will tell you that it is not rare hehe. I had such a case after the founding lpg. I changed the candles, changed the coil, almost a year is already git. With a mate identical case - he set up a lpg, fired the coil, did not change the candle, after a few days drove the second, translated from me 100% good and drowned koilSo he decided to change the candle and the problem disappeared. What's funny, together with me and him (ie 4 coils) all had a piercing in the corpus. You guysthe cost of theHe was about 900zł in a week
  4. #44
    banned Romeo
    He joined the
    02 2011
    Lives in
    Bydgoszcz
    166 2.5V6 CF2 4HP20
    Posts
    655
    I do not write nonsense. Just look at the construction of the coil ...... It had to break the corpse and it was pierced on top. And this is a rarity.
    All defective coils I had the opportunity to replace in the V6 also had a cracked plastic body. Case?
  5. #45
    The user Cyclist
    He joined the
    03 2013
    Lives in
    Hajnowka
    Posts
    61
    Quotation Wrote feecle Zobacz post
    O ikoilPer person. Rather doubt it was a rarity.
    Quotation Wrote dcfan Zobacz post
    I'm also curious. Do you have a picture of what it looks like at V6?
  6. #46
    He joined the
    05 2009
    Lives in
    Strzelin
    Posts
    12,644
    It is possible that the corpses are cracking Anyway if you look at the break just above the top it is not reliable because it may well be underneath and "G" will see.
    And with these coils from marea it's good ....
  7. #47
    The user Cyclist
    He joined the
    03 2013
    Lives in
    Hajnowka
    Posts
    61
    Buddy that I told you above, the first coil as he ordered it was said bad to him and it turned out that it was from marei was. PASOShe screwed on the screw, the candle also came in, but there was a problem with the plug.
  8. #48
    He joined the
    05 2009
    Lives in
    Strzelin
    Posts
    12,644
    Plugin is not a problem. Of course for wanting.
  9. #49
    The user The alpha and the Omega Avatar Aroniaa
    He joined the
    12 2011
    Lives in
    Olkusz
    AR 166 3.0v6 azurro nuvola
    Posts
    474
    Hi, I'm going to refresh the topic about coils, I have the same problem as most V6 owners. And the fact the cost of the The new divine coil is an expense of 250 zlotys so not much, but I see that you write about matching coils from marea or about these coils? http://allegro.pl/cewka-zaplonowa-fi...109050330.html
  10. #50
    The user Expert
    He joined the
    11 2009
    Lives in
    Rybnik
    Alfa 166 2.5V6 była; Alfa Gtv 2.0 TS 2001
    Posts
    1,035
    Quotation Wrote Aroniaa Zobacz post
    Exactly this coil has even an identical plug.
Similar threads
  1. Or TS 16V possible high voltage cables?
    Created by Jerry1 in section 156
    Response: 22
    Last post/author: 20-06-2014, 10:28
  2. [164] High tension leads.
    Created by tytus_w in the section 33/164
    Response: 22
    Last post/author: 23-01-2014, 22:19
  3. [164] the high-tension cables
    Created by Miłosz in the section 33/164
    Response: 1
    Last post/author: 05-10-2008, 07:49
  4. [164] 2.0 TS - how to check coil of high voltage?
    Created by fr33 in the section 33/164
    Response: 6
    Last post/author: 25-02-2008, 00:29
coil ml 3 2 v6
cl320 Tesla coil alfa 166
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
