Page 3 with 5 The firstThe first 12345 LastLast
Show results from 21 to 30 with 50
  1. #21
    DDEvil
    A guest
    it's not you then klucice and tomorrow I will about 16 jade for the site and sma I know, because I will, we're under comp podpinal with Respect
    › Więcej...: Indicator wtryskow
  2. #22
    An administrator. the moderators Quadrifoglio Verde Avatar 75andrew155
    He joined the
    05 2006
    Lives in
    Warsaw, Poland
    155 V6 1996. r 155V6 1995 3.0 12V
    Posts
    11,237
    While only three of us here where extinguished light is injection after the shot engineand . I have and error in electronics no
    Alfa Romeo 75 Turbo 1987
    Alfa Romeo 75 Turbo America 1990
    Alfa Romeo Giulietta 1.6 1983
    Alfa Romeo 145 1.4 boxer, 1997
    Alfa Romeo 155 V6 1996
    Alfa Romeo 155 V6 1993 3.0 12V spacer to the 1.8 8v 1995
  3. #23
    VIP Romeo Avatar Mdx
    He joined the
    12 2006
    Lives in
    Kraków, Poland
    Volvo V60 D4 2015r.
    Posts
    532
    In my 155 since then, how I have (almost 2 years) after turning the ignition key lights 3 bulbs included : battery , oil, ABS ( fades out after a few seconds ) - the oil and the battery after starting engineand turns off.
    this means that something is wrong, time is off but light is injection or my model, as it should be ??
    When you don't give advice, and you further.... then Kyokushin
  4. #24
    He joined the
    05 2006
    Lives in
    Warsaw, Poland
    Posts
    11,237
    Probably a light bulb, but I would nieprzejnował worse, as if franca smoked
  5. #25
    He joined the
    12 2006
    Lives in
    Kraków, Poland
    Volvo V60 D4 2015r.
    Posts
    532
    Quotation Wrote 75andrew155
    rather, it has to be good, because some time ago, the guy gave me all жеaróweczki in the counter.
    I have to ask my mechanicand this on one occasion ;//
  6. #26
    VIP Expert Avatar Rigidigi
    He joined the
    04 2006
    Lives in
    SB and WX Y..
    166 Q2 2.5 V6, była 145 1.6TS, była 147 1.6TS
    Posts
    1,108
    Today specially checked, as I have.
    Usually the fires engine at that moment, the end of "howl" fuel pump. Indicators will extinguish, then after 2-3 seconds after starting the engine.
    But if I wait a minute longer with the machine, the light injection disappears after approximately 5 seconds.
  7. #27
    He joined the
    12 2006
    Lives in
    Kraków, Poland
    Volvo V60 D4 2015r.
    Posts
    532
    Quotation Wrote marcins737
    in General, as uprzesz you can check whether the meter comes back the voltage after turning the ignition key
    loosen the two screws will be sufficient for another kind of counter not keep ??
  8. #28
    DDEvil
    A guest
    well, today I was in the service, will dispel your doubts in the scheme engineand as I is what light is injection goes out you at the time of launch is the norm, not an error, and all, and as in other models, it is not my business Best regards
  9. #29
    He joined the
    10 2005
    Lives in
    PL
    Alpha crash on the day of purchase and this State lasts until the day of the sale.
    Posts
    7,540
    buddy mdx in this Yearbook was not the bulb check
  10. #30
    The user Romeo Avatar kaes
    He joined the
    02 2007
    Lives in
    Lublin
    AR 145 1.4 bx 1995
    Posts
    787
    6 to 3, to my version. :mrgreen: :twisted:
    Wziuuuuuuuuuuuuuuuuuuuuuuuum ... What was that? Such a quick and beautiful?
    It's 145 boxer of course!
Similar threads
  1. [146] Alfa 146 1.4 ts indicator wtryskow it's not gasoline
    Created by sylwunio1989 in the section 145/146/155
    Response: 5
    Last post/author: 24-12-2011, 11:39
  2. [146] Indicator wtryskow and water ???????
    Created by remi200833 in the section 145/146/155
    Response: 5
    Last post/author: 06-01-2011, 22:40
  3. Response: 3
    Last post/author: 27-11-2008, 16:25
  4. Indicator wtryskow above 3500 rpm. JOKES
    Created by przemekj23 in section 156
    Response: 7
    Last post/author: 26-11-2008, 22:27
  5. From wtryskow indicator is lit all the time....
    Created by Lukas469 in the section 145/146/155
    Response: 2
    Last post/author: 28-10-2007, 19:27
Tags for this topic
Permissions
  • You can not assume a new topic
  • You can not write messages
  • You can not add attachments
  • You can not edit your posts
Shock absorbers
